AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
BOM IN EXCEL
3 REPLIES 3
psrajesh4u
873 Views, 3 Replies
BOM IN EXCEL
When generating BOM to excel I get the values of Query, user & misc lines to the separate columns.  If I merge these columns i get only first coulum data.I need to get all these values in to my descriptions columns like report generated in the style of "put on drawing" ( in normal tailed format). Is it possible? if yes please reply.
Rajesh.
3 REPLIES 3
JMARSHALL1249
in reply to: psrajesh4u
If I've understood you proberly, try this...
Lets assume Description lines 1, 2 & 3 sit within excel boxes A2, B2 & C2.
In a spare column in row 2 type the following:-
=A2&" "&B2&" "&C2 and press enter
This will combine the descriptions into one cell, but as a formula.  Drag the bottom right corner of the cell down to generate combined descriptions for all rows of your BOM.
Select all these new cells, Right click the selection, select 'COPY'
in another spare column in row2, right click again and select 'Paste option 'values'
This will now give you the combined descriptions as raw text for your BOM.
Hope this makes sense.
psrajesh4u
in reply to: JMARSHALL1249
It is working. Thankyou for your support.
regards,
Rajesh.
rwydesk500
Otherwise known as "concatenate", in Excel.
Rick Yoerger
AutoCAD Electrical 2016
”Boost
