AutoCAD Electrical General Discussion
psrajesh4u
Message 1 of 4 (552 Views)
BOM IN EXCEL
552 Views, 3 Replies
11-01-2012 07:53 AM
When generating BOM to excel I get the values of Query, user & misc lines to the separate columns.  If I merge these columns i get only first coulum data.I need to get all these values in to my descriptions columns like report generated in the style of "put on drawing" ( in normal tailed format). Is it possible? if yes please reply.
Rajesh.
Valued Contributor
JMARSHALL1249
Message 2 of 4 (548 Views)
Re: BOM IN EXCEL
11-01-2012 08:32 AM in reply to: psrajesh4u
If I've understood you proberly, try this...
Lets assume Description lines 1, 2 & 3 sit within excel boxes A2, B2 & C2.
In a spare column in row 2 type the following:-
=A2&" "&B2&" "&C2 and press enter
This will combine the descriptions into one cell, but as a formula.  Drag the bottom right corner of the cell down to generate combined descriptions for all rows of your BOM.
Select all these new cells, Right click the selection, select 'COPY'
in another spare column in row2, right click again and select 'Paste option 'values'
This will now give you the combined descriptions as raw text for your BOM.
Hope this makes sense.
psrajesh4u
Message 3 of 4 (534 Views)
Re: BOM IN EXCEL
11-01-2012 08:05 PM in reply to: JMARSHALL1249
It is working. Thankyou for your support.
regards,
Rajesh.
Valued Contributor
rwydesk500
Message 4 of 4 (311 Views)
Re: BOM IN EXCEL
11-13-2012 12:14 PM in reply to: psrajesh4u
Otherwise known as "concatenate", in Excel.
Rick Yoerger
AutoCAD Electrical 2014
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
