AutoCAD Electrical General
Nicolas.L
Message 1 of 3 (342 Views)
Automaticly generate my electrical schema from .xls data
342 Views, 2 Replies
12-06-2012 12:15 AM
Hello eveyone,
I am new in Autocad Electrical 2013 and i am trying to automatism my work.
After a quick look on the others topics i do not found the answers of my problem.
I have thought of first create a base for my entire project in .dwt
Then realize different .dwg like a library
The last thing is using VBA and a excel sheet to import only the items i need.
My questions are : Is it the good way to do ?
                               Is someone able to tell me how i can import in a .dwg another one like a block (in VBA) ?
I have tried this :
Sub Test_Insert()
Dim pts(0 To 2) As Double
pts(0) = 20: pts(1) = 20: pts(2) = 0
ThisDrawing.Blocks.Add(pts,"C:\path\file1.dwg")
End Sub
Of course it is not working :smileyhappy:
If someone can help, having example or answer or anything else which can help, I will be great full.
Thanks by advance
Regards
Nicolas
Ps: Sry for my frenchy English
rhesusminus
Message 2 of 3 (336 Views)
Re: Automaticly generate my electrical schema from .xls data
12-06-2012 02:45 AM in reply to: Nicolas.L
To answer your VBA-question.
You are trying to add a new block to the drawings block-library.
To insert a block into a drawing (creating a block reference), try this code:
Sub Test_Insert()
ThisDrawing.ModelSpace.InsertBlock pts, "C:\path\file1.dwg", 1, 1, 1, 0
End Sub
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Nicolas.L
Message 3 of 3 (325 Views)
12-06-2012 06:14 AM in reply to: rhesusminus
Spoiler
Thanks a lot, I have tried your cod and it is working well!
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
