AutoCAD Electrical General
New Member
Peter_Scholey
Message 1 of 3 (252 Views)
Automatic wire tagging not tagging all wires?
252 Views, 2 Replies
01-20-2013 10:19 PM
Hello
I'm fairly new to autodesk, I have tried the drawing wide auto wire tag and it doesn't seem to be tagging all of the wires any suggestions from you guys why it might be doing this?
Any help appreciated
Cheers
Peter
dougmcalexander
Message 2 of 3 (236 Views)
Re: Automatic wire tagging not tagging all wires?
01-21-2013 08:15 AM in reply to: Peter_Scholey
Be sure that the terminal block symbols on those un-numbered wires are of the type to force a wire number change. It appears that you prefer to assign a different wire number to field wires. You must force the wire number change by using a terminal or connector that changes the wire number as it passes through. Hint: This type of terminal or connector must also be used if your field wires are set for no wire numbering.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
gtralt
Message 3 of 3 (197 Views)
01-24-2013 05:26 AM in reply to: Peter_Scholey
Also check that your wire layers are able to be numbered. Type AEWIRETYPE in ther command line and make sure that the wire numbering box for the wire layer that you are trying number has "YES" in it.
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
