Attached is a script file a created for you. It has parameters set to special explode everything from coordinates 0.4,0.5 to 30,22 on a D-size sheet. You will need to adjust those coordinates to capture the objects you wish to explode. Be sure to keep the coordinates inside your border or you might accidentally explode your border and lose the title block information.
I cannot post a fle with the .SCR extension due to security protocols on this forum. I will post it with a .zip extension. Just rename it to specialexplode.scr after downloading and it should work fine.
Be careful when editing the script. There is a space bar at the end of the line and a return. These are necessary. You cannot see them but your cursor can find them. All you should really need to do is move your crosshair around inside your drawing and select the start and end coordinates for the select objects window and replace my coordinates with what you find. Test this on one drawing by typing SCR at the command line and browsing to wherever you saved the script file. If it works correctly you can try editing drawing entities and you will notice that they are all just dumb lines, circles, rectangles, and text. Execute from the project-wide utilities under the project manager fly-out to special explode all drawings in a project.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
