I'm installing autocad electrical 2015 but when installing finish i can not get catalog at catalog menu.
can you give me problem solving for that sir??
Best Ragards
Dave
Best Ragards
Dave
If you didn't do anything specail during installation, you should find the DEFAULT_CAT.MDB file at:
My Documents\Acade 2015\AeData\en-US\Catlogs
Can you confirm that this directory exist, and that you can find the default_cat.mdb file there?
AutoCAD Electrical searches the location specified in the WD_CAT line of the WD.ENV file for a catalog named either the same as your current project, or named default_cat.mdb. Check the WD_CAT line of your environment file to see where it points.
Find "default_cat.mdb" and place into the folder where wd.env file exists.
it worked for me.
