AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Autocad electrical 2013 deployment setup
2 REPLIES 2
321 Views, 2 Replies
I was asked to tackle this but have never created a deployment file before. I would guess that this has been asked before, but is there a step by step guide to do this to include file sharing of the databases and other items that may need to be configrured? I know if done wrong may cause issues down the road when upgrading.
thanks
Jason
2 REPLIES 2
rhesusminus
If you log on to AU online, Eric France and Stan Wile had a good class on this a few months ago.
You can download all you need to read here:
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2013/autocad-electrical/ma1600
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
We created the deployment file and specified the locations of the shared folders. It created the files on our network. But what seems to happen is that when adding a symbol, the menu still points to the local hard drive. Is there a way to change the path or does it need to be done in the wd.env file? If so what needs to be edited in the wd.env file? I looked at the presentation but didnt quite understand what needed to be modified and modified to what. If the wd.env needs to be modified, what type of editor should i use to change the file? Notepad?
thanks
Jason
”Boost
