AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Autocad Electrical - Activated project is not showing new drawings
9 REPLIES 9
Message 1 of 10
1326 Views, 9 Replies
I'm trying to follow the Autocad Electrical 2013 tutorial and immediately I'm having problems.
The problem is when I create a new project and new drawing, the project manager does not update the project tree to show the new drawing underneath the activated project. I tried double-clicking the project. Tried clicking the refresh icon. Nothing.
When I open the wdp file, the new drawing does not appear in the file.
I can browse to the project folder and see the new drawing file. If I right click on the project and select "Add Drawings" I can add the new drawing.
Any ideas?
9 REPLIES 9
Message 2 of 10
dougmcalexander
You are clicking New Drawing, defining a new drawing file name, template, etc. and the drawing is created but not added to the project? I have never seen this issue.  Are you running with the latest service packs and hotfixes? Have you tried a repair installation?
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 3 of 10
Icemanau
This may be a stupid question, but are you creating the new dwg using the project manager or using the new dwg function in the file menu?
Regards Brad
Brad Coleman, Electrical Draftsman
Message 4 of 10
dougmcalexander
That's a good point Brad. People coming from plain AutoCAD often try to use plain AutoCAD to create snd manage Electrical drawings. And as you know, only certain AutoCAD functions are usable without breaking the intelligence.
Doug McAlexander
Message 5 of 10
in reply to: dougmcalexander
I am trying to create a new drawing via the Project Manager. I right-click on the project folder inside the Project manager and then select "New Drawing". The new drawing does not appear in the project manager. When I view the wdp file, the file is missing. When I open the project folder using Explorer I can see the new drawing.
I tried to repair the installation but the behavior is the same. Another user at my company has same version (new install) and is not experiencing this behavior.
Message 6 of 10
pqphillips
Have you tried closing and reopening the project file?
Perhaps purging the project database to see if that is the issue?
Message 7 of 10
zalant
in reply to: pqphillips
  • Is your co-working using the same project as you?
  • Is the project stored in a network location or on your local workstation?
To determine whether the issue is tied to any specific project, try activating the default WDDEMO project and see if adding a drawing to it works.  If so, copy the WDDEMO's project folder to where you have the other project stored, then re-open it (WDDEMO) from there and see if you can still add a new drawing to it.
Zac Travis
Message 8 of 10
moeaung31
in reply to: zalant
I also got the same issue. After making New Drawing from Project manager (ACADE 2014) but doesn't show in Project. Rebuild full DB and ACADE close and open again but the same issue. Can not see new drawing in Project files folder. Also not showing in project.wdp.
When I used new drawing again by same name doesn't allow.
Moe
Message 9 of 10
dougmcalexander
Just to clarify, you are using the New Drawing command that is the 3rd icon from the left in Project Manager, right? This opens a dialog that begins with filename, then you select a template, fill in the drawing description fields, etc., and click OK. This adds the new drawing to the active project. I've never had a problem with adding a new drawing so this is interesting.
Doug McAlexander
Message 10 of 10
moeaung31
Sorry my apology. I put file name with :  .After I try just a name without : it works. Thanks for prompt assistance.
Moe
”Boost
