Hello everyone,
Newbie here! I wonder does AutoCAD is restricted to draw One-line diagrams of Electrical distribution systems only? I have started learning AutoCAD today and I didn't find any transformer rated with high voltages (in the order of 18kV/ 345kV) or any generator with 18kV. So I am confused whether we can draw Electrical transmission systems' one-line diagram or not! Please help me out...
In my experience, the blocks for generators/transformers and such doesn't change. The same symbols are used for a 240V/12V as for a 110V/11kV or a 18kV/345kV transformer. This is especially true for single line diagrams.
In a SLD, the generaly accepted symbols for transformers are as follows.
Two intersecting circles, with either a Delta or a Star symbol in the correct places for three phase, single winding.
Three intersecting circles with either a Delta or Star symbol for 3 phase dual winding.
Two intersecting circles for single phase (no symbols)
Three intersecting circles for single phase with dual winding.
Occasianally you will get an arrow or similar going through one of the circles which indicates a variable output.
There may be some other symbols used but these are the most common.
Generators are usually a circly with a 'G' inside it along with an indicator for single or 3 phase.
As for letting people know what voltages/current are required, all you need to do is set the rating in the Edit Component dialog box and this information will be displayed next to the block.
Regards Brad
Brad Coleman, Electrical Draftsman
