AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
AutoCAD Elec 2010 - Connector TERMDESCxx
0 REPLIES 0
Message 1 of 1
DAKasmis
206 Views, 0 Replies
The way my team wants the connector plug and receptacle to look is backwards from the default.
We want the TERMDESCxx to be on the side opposite PIN (Connection). AutoCAD Default is to put the PIN label above the wire that connects the Pin
Me                                               Them
                                                             DESC
DESC |)------                                      |)----------
I manually changed the blocks and got it to go where I want it, but it will not dynamically size. The text is always 0.25 away from center, but the default block desciption (unedited) is always 0.1 away from the pin.
Is there a way I can easily flip the side the description is on and keep it dynamic? The J or P at the end of the TERMDESC seems to change an anchor point.
0 REPLIES 0
”Boost
