Currently having an issue with AutoCAD Electrical 2013 Report Generator. I have projects that have about 100 drawings and I can run a report on a single drawing but when I do the entire project it gets hung up. I was able to create project reports for about a week with no problems. Now when I select the entire project it gets hung up like its processing and you can hear the ding sound when I left click the mouse button. After about 5 minutes of no response I can hit the escape button and it will bring me back. Please Help.
rbn
Solved by rhesusminus. Go to Solution.
When I select the ACTIVE DRAWING, it creates the report with no problem. When I select the entire project it gives me nothing.
Thats what it sounds like. I cant find the box if it is. When I press the space bar, it just comes back to the drawing.
Are you comfortable with using Regedit (Registry editor)?
Exit AutoCAD Electrical
Start regedit
Have a look at the key HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-E00?:409\Ace_pick_dwgs
Set the values nTopLeftX3 and nTopLeftY3 to 0
restart AcadE and check if you can see this dialog now, when chosing to create report for entire project.
Wow it worked. Thank you very much it helped an it now works but now the Active drawing (all) and Active drawing (pick) radial buttons are not highlighted but I will play with it. Thats the least of my problems. Thanks again and now I'm back in business.
rbn
I have found that when working with multiple screens sometimes the dialog boxes end up "off screen". When this happens I use
ALT+SPACE then M
Now you can use the arrow keys to move the dialog box around.
