I created some custom symbols in AUTOCAD 2013 with additional attributes (SubAssy1, SubAssy2 etc.,). When i inserted the new symbol into the schematic, the additional attributes are not showing up in the "edit miscellaneous box".
The attached snapshot is from the symbol created in ACAD 2011 and the attributes "SubAssy1 & SubAssy2" are shown if we open in ACAD 2011 but not showing up when we open in 2013 and when we create a new symbol in 2013 as well.
The default path for the symbols library Template is set to "C:/Users/Public/Documents/Autodesk/ACADE 2013/Libs/Jic1
Any help would be greatly appreciated.
Prabhakaran.D
My first thought twas that you didn't update the block in the drawing, but if it IS there when using 2011, tht blows that out of the water.
I have not had this sort of problem. I have custom attributes in many symbols, both parent and child symbols. I even added your attributes to a symbol and tried it. Not a problem. Can you post a sample project with a drawing containing those symbols for people to check out?
