I have changed the connecetor symbols to have the TERMDESCxx always be black instead of based on per layer.
This works wonderful until I change the connector after it is added (stretch, split). After changing the connector it gets $$ in its name and the TERMDESCxx seem to go back to per layer coloring.
Did I miss changing some drawings? I don't see any extra blocks listed after a connector change.
When you stretch or modify the symbol in any way after it has been inserted, ACAD has to change the block name. If it didn't it would cause problems with accessing the block on the hard drive.
As for the colour's changing, I have no idea on that apart from ACAD defaulting to a setting somewhere and the attribute being changed to match said setting.
I would assume that you want just the termdesc for the connectors to be black and not the termdesc for ordinary terminals as well. The only solution I can think of is to create a layer for the termdesc and set it's colour to black. Then edit the connector blocks again and change the attribute to that layer. The final step would be to change the dwg and project settings to only modify attribute layers if the are on layer 0.
To change the layer settings, go to project (or dwg) settings and select the Drawing Format tab. Click on the Define button in the layers box. Now select the checkbox down the bottom, titled 'Apply to entities on layer "0" only'. Make any other changes you desire as well.
Hopefully this will fix your problem.
Regards Brad
Brad Coleman, Electrical Draftsman
Thank You.
That Project (DWG) Setting 'Apply to entities on layer "0" only' seems to have fixed what I was seeing.
I can split and change the connector and it doesn't go back to a default color.
Thank You Again!
