I'm looking into using the autoreport generator and have come up with the following inconsistencies between that and the manual report tool.
Has anyone else come across these problems? Are they bugs or inconsistencies?
1) In the manual report tool for the schematics there is the option to add blanks between entries. On screen, these blanks do show however they don't appear when the report is printed. I've tried several printers and the result is the same.
2) When using the automatic report tool, there is no option to include these blanks. Should there be this option?
The next two are questions
3) The report tool gives the option to add project lines but is there a way to give these project lines a title so that they actually mean something. We have a project number which is purely digits, for exampe 12345; if this was seen on a drawing without a title, it could mean anything!!
4) In the automatic tool under the 'Save Report to File' section you can specify a report name. Is there any way to enter the path and a variable which makes the saved filename that of the project title?
If anyone can help with these questions, it would be appreciated.
