AutoCAD Electrical Forum
Welcome to Autodeskā€™s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Attribute dialog box does not display
1 REPLY 1
wassapi
989 Views, 1 Reply
I am an occasional AutoCAD user.
When I open an existing AutoCAD drawing, click the "Insert Component" button, at the bottom of the AutoCAD screen, the command line displays "Enter new value for ATTREQ <1>:" instead of display a dialog box with selections.
I searched the AutoCAD web site and found the following message stated that I have to modify the AutoLISP file.
But the problem is that I don't know which *.LSP file to modify. I tried the file: "attredef.lsp". What's in the file did not match exactly to what the following message indicated. It didn't work either. Anyone can help me by identify what is the specific file name, and where is the described text locate.
Published date: 1999-09-29
Applies to:
AutoCADĀ® 2000
Issue
The following AutoLISP code does not work correctly even though the same syntax is functional in AutoCAD Release 14:
(setvar "ATTREQ" 1)
(setvar "ATTDIA" 1)
(command "-insert" "MyBlock" InsertionPoint Xscale Yscale Zscale Rotation)
The code inserts a block with attributes, then displays the Enter Attributes dialog box (where the attributes are entered), and the block is placed in the drawing.
Solution
This functionality is new in AutoCAD 2000. The Insert Attribute dialog box will not display when called from an AutoLISP function unless ATTDIA is set to 1, and the INITDIA function is called prior to executing the -INSERT command.
To do this, the AutoLISP code needs to be as follows:
(setvar "ATTREQ" 1)
(setvar "ATTDIA" 1)
(initdia)
1 REPLY 1
in reply to: wassapi
What version of AutoCAD Electrical do you have (Acade 2005, acade 2006,
Acade 2007)?
Also, when this happens, could you hit the F2 key to get to the text screen
and see if there are any other messages above the message: "Enter new value
for ATTREQ <1>:"
It is acting like it is unable to find the menu file that controls the
Insert Component dialog. This file woudl be name something like:
ACE_JIC_MENU.DAT
Steve
wrote in message news:5153487@discussion.autodesk.com...
selections.
locate.
Applies to:
AutoCADĀ® 2000
Issue
(setvar "ATTREQ" 1)
(setvar "ATTDIA" 1)
the drawing.
Solution
command.
(setvar "ATTREQ" 1)
(setvar "ATTDIA" 1)
(initdia)
ā€Boost
