AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Arrange MENU tools order?
2 REPLIES 2
Tim_L
215 Views, 2 Replies
Hi there,
Here is the duu question of the day.
I used the MENU command at the command line and loaded acade.cui. I would like to have the standard ACAD menu tools listed first, then the ACE menu tools listed second. In the Customize User Interface I do not see how to change the order to menus are loaded. Can someone please tell me how to change to order or point me to the ‘procedure’ in the help files.
Please see the attached picture. I would like the order to be listed as
File Edit View Format … Components Panel Layout Help
Thank you
2 REPLIES 2
JeffatSJE
in reply to: Tim_L
I had that same problem and unloaded both menus then loaded acad first. Once you get the menus the way you like you might want to create and save a custom workspace.
Tim_L
in reply to: Tim_L
Worked fine. It is one of those commands that gets used once a year or so and I have a hard time remembering breakfast, ha.
Thanks again for the help Jeff
”Boost
