Hi there,
Here is the duu question of the day.
I used the MENU command at the command line and loaded acade.cui. I would like to have the standard ACAD menu tools listed first, then the ACE menu tools listed second. In the Customize User Interface I do not see how to change the order to menus are loaded. Can someone please tell me how to change to order or point me to the ‘procedure’ in the help files.
Please see the attached picture. I would like the order to be listed as
File Edit View Format … Components Panel Layout Help
Thank you
