(c:wd_retag_update_noprompts options
ent_lst)
Replaces obsolete functions wd_update_circ_noprmpts
and wd_retag_comp.
Re-tag schematic component(s) on current dwg or
across active project.
"options" = 1's bit to do
dwg-wide retag update without asking if okay, =0 user prompt to select
components to retag, user prompted for okay to check other dwgs in project for
related children (unless bit 32 set).
"options" = 2's
color=#0000ff>also do project wide retag update without asking if
okay.
"options" = 4's bit set = DESCx was changed on parent
and nothing else.
"options" = 8's bit set = DESCx changed on parent
along with TAG, CAT, or something else significant.
"options" = 16's bit set = processing/updating CHILD
cross-refs only (no retag).
"options" = 32's bit set = (with 1's bit set) -
suppress child check on other dwgs of project.
"options" = 64's bit set = (with 1's bet set) -
suppress project child "Now/Later" dialog, do "Now".
"ent_lst" = (with 1's bit set), nil=do all components
on dwg, OR else do ents passed in this argument. Can be single entity name,
entity handle, list of entity names, list of entity handles, or selection
set.
