Nate,
Are you getting closer to this? I really want to be able to put my ground wires on a wire layer but I do not want them to have a wire number. It is a pain to have to draw the ground wire connections and then have to go back and move them to 0 so that they will not be numbered. Then I have to move them back so that they can use the wire info for that layer. Then later on, I may have to renumber the wires and I have to go through this all over again.
I also will use another layer for multiconductor cable that will use the color of the wire instead of a wire number. This is why I am adamant about being able to do this. Could it be a selectable for a given layer?
Also, I am restating that I want Check All to work for all check boxes in the Update Project window. Or at least another one for the per drawing variables. I now have to check 6 boxes instead of one when I update my drawings. Changing this was kind of a step backwards.
Robert Hanrahan
Weigh Right Automatic Scale Co.
ACE user since 1998
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
