time my user has a cable that splits into the individual wires. If he connects the top wire it wants to move the label to the far left side on the cable. If he breaks it from the cable it will work fine and be in the correct location at the #.
Take a look and let me know if you can see a problem.
This
This is an inherent problem with the Fan In/Out symbols. Have your designer just move the wire number to where you want it to be located using Move Wire Number.
