AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Adding tables programmatically taking time in Windows 7 64-bit
3 REPLIES 3
chaitu123
290 Views, 3 Replies
Hi All,
  We have a vba module which generates drawings which consists of data in tables. We have used AcadTable object to add tables and update the cells. The VBA module is working fine in windows XP with AutoCAD Electrical 2011 but in Windows 7 64-bit it is taking more time and even sometimes not generating all the drawings. I have even used RegenerateTableSuppressed True before setting text in cells of the table and RegenerateTableSuppressed False after updating the table.  Please let me know how i can resolve this issue. Thanks in advance.
Best Regards
Chaitanyag
3 REPLIES 3
Hello, Chaitanyag
Would you please help to attach some sample script for us to reproduce your issue? and also it is better to attach a screenshot to show the issue, then we can help.
And please confirm you are using the ACE2011 SP2.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
Hello, Robin Shou
    The following is some of piece of code
    Dim TabObject As AcadTable
    Dim someInsPoint(2) As Double
    Dim i,i1 As Long
    Dim valStr As String
   set TabObject = ThisDrawing.ModelSpace.AddTable(someInsPoint, numberofrows, numberofcolumns , 0.2, 0.5)
   TabObject .RegenerateTableSuppressed = True
   For i  = LBound(someArray) To UBound(someArray)
        TabObject .SetText i + 2, 0, someArray(i)
        TabObject .SetRowHeight i+ 2, 0.05
        TabObject .SetTextHeight i+ 2, 0.05
   Next
   For i1  = LBound(someArray) To UBound(someArray)
        'Reading database
       'stringval is the value read from a database
        TabObject .SetText i1 + 2, somecolumn, stringval
    Next
   TabObject .RegenerateTableSuppressed = False
  The same code is working finewith windows XP which is taking around x minutes for completion where as the same in windows 7 64- bit is taking around 6x - 7x minutes.
  I have installed Update 1 and Update 2, but still the time taken is same. Please let me know any other patches to be installed.
    Thanks for your reply.
Best Regards
Chaitanya
Hi Chaitanya,
With your piece of code, i can't see anything related to the performance.
Can you provide the whole DVB file and then we can look into it. And also if the file can only run in your Project, then i think a sample project you also need to provide.
If you don't want to attach the files and sample project in the discussion group. Please send me the email directly. you can use zhonghua.shou@autodesk.com
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
”Boost
