AutoCAD Electrical Forum
Add Spacer Line to parametric PLC
2 REPLIES 2
Pertech-LLC
378 Views, 2 Replies
I regurally add a spacer line to a parametric PLC through the PLC to spreadsheet utility. Is there a way to add the spacer after a PLC has already been inserted?
I'm coming back to an older project, & need to add some space for a new circuit between I?O points.
All help appreciated,
2 REPLIES 2
rhesusminus
in reply to: Pertech-LLC
There is no way to update your already inserted PLC module, but have a look at the "Stretch PLC Module" command. It might help you achieve what you want.
THL
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Pertech-LLC
That is the command I was looking for.
Thank You
”Boost
