I can not activate the "Family" in dialogue "Descriptions list".
Create a file "PB.wdd" and want to use it for the inserted button.
What am I doing wrong?
Solved by galashkina. Go to Solution.
According to the name of that "windows" (see your image) you ARE using the PB.WDD...
Actually from the title bar in your image it looks like it is already using the pb.wdd file. This is why the button is disabled. It will default to the most specific file possible when the dialog opens. If you pick the General button to switch over to the general file, the Family button should enable.
Hope this helps,
Pat Murnen
Thank you for your willingness to help me.
I upload files using the "Project" button and "General" button, but "Family" button is not always active.
File "PB.wdd" I can only open the "Pick File" button.
Maybe should be a different file name?
