AutoCAD Electrical Forum
Acade2008 confuses same tag different loc components
1 REPLY 1
hpenza
221 Views, 1 Reply
In the field I have existing old components to draw with same tag an different Loc. Acade confuses them as the same.
Obviously are different. Example a relay in one panel list the contacts of other relay(same tag and different location) in other panel.
¿How I could solve that?
I am using Acade 2008 SP2
1 REPLY 1
in reply to: hpenza
AcadE has 2 different tagging modes - tag only and combined
tag/installation/location mode. This is a project setting. Make sure your
project is set to the combined tag mode by these steps -
1. in Project Manager right-click on project name
2. select Properties
3. select Components tab
4. Make sure Combined Installation/Location tag mode is checked.
There are also some related settings for this that you should look at and
set to your preferences.
Pat Murnen
wrote in message news:6006386@discussion.autodesk.com...
”Boost
