<I
href="mailto:kristi.brooks@invie.com">kristi.brooks@invie.com> wrote in
message
href="news:6053150@discussion.autodesk.com">news:6053150@discussion.autodesk.com...
understand from previous posts that the transition from ACADE2005 to ACADE2006
was when the .wdp file started using relative paths to record where the
drawing files were located instead of absolute paths. Does anybody know of any
way to use absolute paths instead? Is there a setting to use to indicate
preference? We're using both 2007 and 2009 in the office here. Thanks,
Kristi
<brutech@charter.net>You
wrote in message
href="news:6054432@discussion.autodesk.com">news:6054432@discussion.autodesk.com...
can also use absolute paths by manually editing the drawing paths in the
project (.WDP) file using an external text editor such as Notepad. Every
drawing path has to be edited.
<Mike
message
href="news:6054679@discussion.autodesk.com">news:6054679@discussion.autodesk.com...
is right on regarding this. I like to use absolute paths because when I am
told I have to rearrange the way I organize my files I don't have to spend so
much time re-editing each and every project file. I'm not sure how using
relative paths would be an improvement. You're counting on something to stay
the same and if that 'something' has to move then you have to edit every
single project file affected. We save our drawings on a server (same server we
save all our .wdp files and other necessary ACADE files) and when the server
was renamed it was relatively easy to do a massive search/replace in every
project file to rename the server in the path. Now I need to open each project
and deal with the errors that pop up because the path to the files is
incorrect. I would wholeheartedly support having the option to go back to
absolute paths. Kristi
"kristib" wrote in messageMike,
href="news:6055614@discussion.autodesk.com">news:6055614@discussion.autodesk.com...
What I'm being asked to do it more complicated than just moving the whole
project (project file and dwg files). It's your 2nd scenario that is closer to
what I'm asked to do. I haven't been able to convince those in authority over
me against another total rearrange. We do this every 12-18 months, with the
assurance that this is the last time I'll be asked to do it. Thanks for the
explanation. Kristi
