AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
API c:wd_getattrval to copy a block attribute to titleblock attribute
4 REPLIES 4
garet79
465 Views, 4 Replies
I've been referencing post "Replace certain attribute value script?"  I want to scan a drawing for three custom blocks , if found, then transfer their "INST" value (ex. 123456) to their respective custom attribute on the titleblock(dwg1, dwg2, dwg3).  So far...
(defun c:bl()
    (setq gt (ssget "_X" '((2 . "HDV1_GENERIC_BLOCK_LEFT"))))
    (setq ik 0)
    (if (< ik (sslength gt))
        (progn
        (setq ent (ssname gt ik))
        (setq rtrn (c:wd_getattrval ent "INST"))
        (princ rtrn)
(princ)
I'm using Group Code 2, as you can see, but my block HDV1_GENERIC_BLOCK_LEFT is dynamic so when it changes from its inserted version the Group Code also changes.  I tried adding the new Code description (*U10) to my list but still get ; error: bad argument type: lselsetp nil.  Are dynamic blocks out of the question when working with entities or is their a way around this problem?
4 REPLIES 4
vladop
in reply to: garet79
To find real block name use (vlax-get-property object 'EffectiveName).
Also, change "if" to "while" loop with ik incrementation.
Following code should work:
(defun c:bl()
  (setq gt (ssget "_X" '((0 . "INSERT"))))
  (setq ik 0)
  (while (< ik (sslength gt))
    (setq object (vlax-ename->vla-object ent))
    (setq block_name (vlax-get-property object 'EffectiveName))
    (if (= block_name "HDV1_GENERIC_BLOCK_LEFT")
      (progn
        (princ rtrn)
    (setq ik (1+ ik))
  (princ)
Vladimir
vladop
in reply to: vladop
Added one more line (vl-load-com) just in case.
(defun c:bl()
  (vl-load-com)
  (setq ik 0)
      (progn
        (princ rtrn)
    (setq ik (1+ ik))
  (princ)
garet79
in reply to: vladop
Thanks for the help. Could you give a brief explanation of what those lines do?  As is, the code will only work for the last block inserted.  Inserted HDV1_GENERIC_BLOCK_LEFT and it put the INST value in the correct title block attribute(DWG1).  However, if I insert HDV1_GENERIC_BLOCK_RIGHT it will do the same but then HDV1_GENERIC_BLOCK_LEFT won't work.  I want it to update all three at the same time not based on the last block inserted.(As you can see HDV1_GENERIC_BLOCK_MIDDLE is my third block.)  Since their will only be one instance of each of the three blocks do I need the While loop?  Also if I run the code it updates attribute DWG1 to 111222 for example.  If I change the block INST value to 333666 and run it again I get 111222333666.  If it has a number already there I would like it to erase that number and update based on the current value of INST.  To solve this problem I was thinking using similar code to get the value of the three attributes(dwg1, dwg2, dwg3) and compare to the block INST values and correct accordingly.  What do ya think?
(defun c:bl()
    (vl-load-com)
    (setq ik 0)
        (cond ((= block_name "HDV1_GENERIC_BLOCK_LEFT")
            (setq dg1 (c:wd_getattrval ent "INST"))
            (command "-attedit" "n" "n" "ele_d2b" "dwg1" "" "" dg1)
          ((= block_name "HDV1_GENERIC_BLOCK_MIDDLE")
            (setq dg2 (c:wd_getattrval ent "INST"))
            (command "-attedit" "n" "n" "ele_d2b" "dwg2" "" "" dg2)
          ((= block_name "HDV1_GENERIC_BLOCK_RIGHT")
            (setq dg3 (c:wd_getattrval ent "INST"))
            (command "-attedit" "n" "n" "ele_d2b" "dwg3" "" "" dg3)
    (setq ik (1+ik))
(princ)
vladop
With this line:
all blocks in the drawing are selected, so while loop is used to check them all and find HDV1_GENERIC_BLOCK_... blocks.
I have no idea why other things described happen.
Did you try to find error using Visual LISP debugging menu?
”Boost
