Hello ALL,
I am still having an issue with my ACADDOC.LSP not loading when I am in the SDI=1. if I turn the SDI=0 the ACADDOC.LSP works fine. I have ALWAYS run in the SDI=1 mode. It worked up until about a month ago, something chaged and I cannot figure out what.
Anyone have any ideas what is going on and and idea how to fix this issue???
Dennis
Did you change this one :
Load acad.lsp ?
Try this :
Command: (findfile "acaddoc.lsp")
nil
Command: (findfile "acad.lsp")
"C:\\Users\\USERNAME\\appdata\\roaming\\autodesk\\autocad electrical 2012\\r18.2\\enu\\support\\acad.lsp"
With ACADE 2012 no acaddoc.lsp ?
The acaddoc.lsp file is found in the network place I put it in both the SDI=1 and SDI=1
I tried changing it to load acad.lsp with every drawing with no luck.
When I open an existing drawing this is what I get when SDI=0
Opening an AutoCAD 2007/LT 2007 format file.
Regenerating model.
AutoCAD menu utilities loaded.cmdecho
Enter new value for CMDECHO <1>: 0
*** My acaddoc.lsp loaded ***
AutoCAD Electrical menu utilities loaded.
Command:
Autodesk DWG. This file is a TrustedDWG last saved by an Autodesk application
or Autodesk licensed application.
Command:
when in SDI=1
Regenerating model.
Command:
Command:
Command:
It does not see the ACADDOC.LSP at all
