AutoCAD Electrical Forum
ACE2012 - Symbol Builder Attribute Editor - can't edit all my pin attributes
1 REPLY 1
pwk
427 Views, 1 Reply
I just started using ACE2012.  I had been using ACE2011 previously.  In Symbol Builder, I am trying to edit a symbol I had built previously in ACE2011.  My symbol has 20 pins, each with two attributes (TERMn and TERMDESCn, where "n" is a number 1-20 corresponding to the terminal number).  In Symbol Builder Attribute Editor, when I try to view/edit the text assigned to these pin attributes, I am only able to scroll down as far as the first attribute (TERM19) of pin 19.  I am not able to scroll to TERMDESC19 or either of the attributes for pin 20.  The only way I can veiw/edit the attributes for pins 19 and 20 is to temporarily insert a few extra pins (21 and 22), even though I don't need these pins in my symbol.  Inserting the extra two pins allows me to view/edit the attributes for pins 19 and 20 (although I am not able to view/edit the attributes for pins 21 and 22 after doing this).  After editing the attributes for pins 19 and 20 this way, I can delete pins 21 and 22 and everything seems to be ok.
Has anyone else experienced this strange behaviour?  If you can tell me how I can avoid having to go through this to edit my terminal attributes, I'd really appreciate it.
Thanks in advance,
Paul
1 REPLY 1
pwk
in reply to: pwk
Hi everyone,
Please ignore my previous question.  I closed the symbol builder and opened it up again, and the problem went away.
Thank you,
Paul
”Boost
