AutoCAD Electrical General
Distinguished Contributor pwk
Message 1 of 2 (176 Views)
Accepted Solution
ACE2012 - Symbol Builder Attribute Editor - can't edit all my pin attributes
176 Views, 1 Replies
01-25-2012 12:51 PM
I just started using ACE2012.  I had been using ACE2011 previously.  In Symbol Builder, I am trying to edit a symbol I had built previously in ACE2011.  My symbol has 20 pins, each with two attributes (TERMn and TERMDESCn, where "n" is a number 1-20 corresponding to the terminal number).  In Symbol Builder Attribute Editor, when I try to view/edit the text assigned to these pin attributes, I am only able to scroll down as far as the first attribute (TERM19) of pin 19.  I am not able to scroll to TERMDESC19 or either of the attributes for pin 20.  The only way I can veiw/edit the attributes for pins 19 and 20 is to temporarily insert a few extra pins (21 and 22), even though I don't need these pins in my symbol.  Inserting the extra two pins allows me to view/edit the attributes for pins 19 and 20 (although I am not able to view/edit the attributes for pins 21 and 22 after doing this).  After editing the attributes for pins 19 and 20 this way, I can delete pins 21 and 22 and everything seems to be ok.
Has anyone else experienced this strange behaviour?  If you can tell me how I can avoid having to go through this to edit my terminal attributes, I'd really appreciate it.
Thanks in advance,
Paul
Message 2 of 2 (174 Views)
Re: ACE2012 - Symbol Builder Attribute Editor - can't edit all my pin attributes
01-25-2012 01:31 PM in reply to: pwk
Hi everyone,
Please ignore my previous question.  I closed the symbol builder and opened it up again, and the problem went away.
Thank you,
Paul
You are not logged in.
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
