AutoCAD Electrical General
Active Contributor
elprim
Message 1 of 8 (350 Views)
ACE2012 Link components & reverse component
350 Views, 7 Replies
09-11-2012 05:17 AM
Hi
What is the right way to unlink component
I have reversed the component and then I wasn't able to connect wire,
 the connection was made over component, what I make wrong
Thank for help, Vito
Kind regards, Vito
testsubject
Message 2 of 8 (347 Views)
Re: ACE2012 Link components & reverse component
09-11-2012 05:58 AM in reply to: elprim
How did you reverse the component? If you simply mirrored it, then ACE will not work properly. You have to use the "Reverse/Flip Component"Command. One way of finding it is to hover over the component and then Right Mouse Click. This command is located near the bottom.
You can use "Trim WIre" to disconnect a component from the wiring.
Bob Hanrahan
Ace User since 1998
Active Contributor
elprim
Message 3 of 8 (344 Views)
09-11-2012 06:30 AM in reply to: testsubject
Hi, I used "Reverse/Flip Component" and result is in attachment
block is VSS21 and VSS113
Thanks, Vito
Kind regards, Vito
testsubject
Message 4 of 8 (340 Views)
09-11-2012 06:36 AM in reply to: elprim
Can you send the .dwg file? I cannot see how the symbol is created done from a jpeg...
Bob Hanrahan
Ace User since 1998
testsubject
Message 5 of 8 (339 Views)
09-11-2012 06:37 AM in reply to: testsubject
Also what library are you using? IEC2, IEC4, JIC1, JIC125, etc? They all use the same file names but the drawings are different.
Bob Hanrahan
Ace User since 1998
Active Contributor
elprim
Message 6 of 8 (337 Views)
09-11-2012 06:45 AM in reply to: testsubject
I use IEC60617 and ACE 2013
Kind regards, Vito
testsubject
Message 7 of 8 (326 Views)
09-11-2012 07:43 AM in reply to: elprim
I am not sure what is wrong.
I had no trouble reversing any of these contacts.
Sorry that I could be of more help.
Bob Hanrahan
Ace User since 1998
Icemanau
Message 8 of 8 (317 Views)
09-11-2012 03:25 PM in reply to: testsubject
When you reversed the contacts, did you check the box to only reverse the graphics?
I've had similar problems in the past when reversing a component and found that if I didn't check that box, the attributes would also be moved but the wire direction wouldn't change.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
