I have recently switched from ACE2009 to 2010. during installation I select IEC as my standard. but after finishing installation I found that it has been installed with JIC standard. all components are in JIC mode. I tried twice. but it is repeated each time. and I am sure I have configured the software in IEC mode. what should I do?
best
Masoome
I see this post was awhile ago. Have you resolved this? To install additional libraries follow these directions (also found at http://wikihelp.autodesk.com/AutoCAD_Electrical/enu/2012/Help/0266-Symbol_L266/0272-Use_mult272)
During installation, you specified which symbol libraries to install. You can install additional symbol libraries later.
Also, make sure your project properties and drawing properties are configured for IEC style tagging.
Pat Murnen
