You can convert existing ladders and make them intelligent using the
convert ladder tool on the conversion tab of the all tools palette.
wrote in message news:5952000@discussion.autodesk.com...
We have many, many dwgs that are "legacy" dwgs from an earlier version of
AutoCAD. Depending on the amount of work needed on a dwg, we would go ahead
and put in new ladders and then add whatever new parts were needed. At
worst, you can still add new symbols to the dwg and edit it manually. The
good news here is that you can run a report on the symbols added. ACE has
many automated functions that make it preferable over base AutoCAD whether
you are doing existing or new dwgs. Good luck.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
