Yes, you need to do just a bit more coding. The call you are making returns
the list of wire segments but it doesn't deal with any "loops" that might be
drawn in as well. Here is your program with a check to look for the loops at
each end of each wire segment. See if this gets you closer to what you are
looking for.
Nate.
(defun c:setwirelayer ( wirelayer / en ed x netlst wirelst wire wired)
(while (setq x (entsel "\nSelect wire to change layer of:"))
(setq en (car x))
(setq ed (entget en))
(if (= (cdr (assoc 0 ed)) "LINE")
(progn ; okay to continue
(if (setq netlst (c:wd_get_wire_netlst en 1))
(progn
(setq wirelst (car netlst))
(foreach wire wirelst
(setq wired (entget wire))
(setq wired (subst (cons 8 wirelayer) (assoc 8 wired) wired))
(entmod wired)
; Check each end of wire for an arc "loop"
(setq end1 (cdr (assoc 10 wired))) ; first end
; Throw a small crossing window around this end
; and try to capture an ARC entity
(setq pt1 (polar end1 (* pi 0.25) 0.05)) ; upper right
(setq pt2 (polar end1 (* pi 1.25) 0.05)) ; lower left
(setq ss (ssget "_C" pt1 pt2 '((0 . "ARC"))))
(if (/= ss nil)
(progn ; captured one or more ARC entities at end1
(setq slen (sslength ss)) ; number of ARCs found
(setq ix 0)
(while (< ix slen)
(setq en (ssname ss ix)) ; get next ARC from selection
set
(setq ed (subst (cons 8 wirelayer) (assoc 8 ed) ed))
(entmod ed)
(setq ix (1+ ix))
(setq ss nil) ; release the selection set
(setq end2 (cdr (assoc 11 wired))) ; second end
(if (/= ss nil)
(setq ix 0)
(while (< ix slen)
set
(entmod ed)
(setq ix (1+ ix))
(princ)
wrote in message news:5047923@discussion.autodesk.com...
I have written a simple program to quickly assign wires to a given layer. I
am using the wd_get_wire_netlst function. Everything works fine except the
function seems to leave out wire loops. I have listed the code below. I have
it called from buttons that pass it a layer name, such as RED_12_THHN. ACE's
built in Wire Layer Utility does not have this problem.
(setq en (car x))
(progn
(entmod wired)
(princ)
