AutoCAD Electrical Forum
ACE 2014: Drawing not shown when printing from modelspace
6 REPLIES 6
530 Views, 6 Replies
When I try to print/plot from modelspace only a few items is printed or shown in preview.
When I do the same thing in paperspace the drawing prints ok and is shown in preview ok.
Anyone got an idea ?
Tried unthawing all layers, turning on all layers thinking maybe there was something wrong there, got no layers used in the modelspace set to noprint.
Tried all I can think of...
6 REPLIES 6
RobinShou-Autodesk
Is it only the Preview problem? After plot, if all the items are plotted?
Can you plot a demo drawing from our demo project? such as the demo01.dwg in the WDDEMO project. If it is the same issue?
If the demo drawings don't have any issue, then can you attach your test drawing? Then we can have a check in our side to see what is the problem.
Robin Shou
Quality Assurance
Autodesk AutoCAD Electrical
in reply to: RobinShou-Autodesk
It only happen with that drawing, none of the others.
It happen both on preview and on the printed paper.
Regards
Birger Håland
Norsafe AS
Norway
Anyone found the problem yet ?
alljones
Hi bhaaland
I've had a quick look at the drawing, what I've found is that the shaded viewport option needed to be changed from RENDERED to AS DISPLAYED, see attachment.
The preview then showed up correctly, I'm not sure about an actual print out as our printer network has failed this morning.
Regards
Allan
RobinShou-Autodesk
alljones' solution is correct, I can plot with all the contents after change the settings to As Displayed.
Robin Shou
Quality Assurance
in reply to: alljones
Well done, thnx 🙂
”Boost
