Is there an issue were wire layers go missing? I am finding myself adding wire layers back when I should not have to.
Rgds,
J.
Just to respond that I have not seen this occur.
Only when I run the Purge All command....
As a workaround, try getting all your layers setup and then exporting the layer setup using the 'Layer States Manager'. Then when you need to add missing layers, you just import the saved layer setup.
Regards Brad
Brad Coleman, Electrical Draftsman
