I had the problem initially when using the "export to spreadsheet" command and running a project-wide report (doing only the active drawing seems to work fine). Now I'm having the same issue when I use the" insert footprint (schematic list)" command. After selecting the options on the dialog box for extract from project, and specifying the location code, nothing happens. It doesn't freeze, it just sits there like it's waiting for the next part of the routine. If i hit ESC, it cancels and I can return to working on the drawing, but otherwise it'll just sit there doing nothing, stuck in between commands it seems.
Thoughts? We're trying to use 2013 and replace 2012, but we keep having to go back to 2012 because these common functions don't work...
Solved by testsubject. Go to Solution.
If you were working with two monitors and changed to one, sometimes one of the dialog boxes will try to display on the now missing display. If you hit ALT+SPACE and then M you can move the dialog box around using the arrow keys.
Duh, I was trying to search for one, but it was off the edge of the 2nd screen (and never wrapped around to the first one). Hadn't seen that before, but for whatever reason it was only when a 'select project drawings to process' box was up. Other popups were fine in ACADE.
Thanks for the fix.
