AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
ACADE and user profiles
1 REPLY 1
135 Views, 1 Reply
Is there any way to point E at a centralized set of files? I have a
client whose network policies allocate less space than E needs.
1 REPLY 1
"Frank Oquendo" wrote in message
news:4844811@discussion.autodesk.com...
This may or may not be what you're looking for... but it is easy to move a
large chunk of the installed data up to a network drive. Here is a piece of
a recent thread in this news group that describes the process:
wrote in message news:4813559@discussion.autodesk.com...
>I am running ACE 2004. I know where the wd.env and PLC *.dat files are
>currently kept. We would like to move them to a network server so all the
>designers are working off the same set of files. We are not sure how to
>get ACE to point to these new locations. Has anyone else tried to do this
>and how was it accomplish?
I think you can pick up the whole folder structure that has the wd.env file
in it and move the whole thing up to a network drive. Then go to your AcadE
OPTIONS --> FILES --> Support File Search Path list and add a path pointing
right at this network drive folder where the wd.env now sits. I think that
this is all you have to do. Give it a try and let me know if this doesn't
work out for you.
You can also move the schematic and panel layout symbol libraries to a
shared network drive. Let me know if the above is "not enough".
”Boost
