Can't handle what?
@rhesusminus wrote:Can't handle what?
Had the same question. Looks like a terminal block of some sort, but I don't recognize it right off. Is it the fact that it is multilevel?
'Cause that can be done no problem.
What I mean is, two terminals with two wire connections each and a bus bar assignment to jumper between them.
Also it would be awesome Autocade would have the added intelligence of knowing which wire to use based on the terminal connection point (perhaps that could be assigned at the terminal's creation).
Can you please post the manufacturer and part number or a link to the data sheet of that terminal? To get out some more information ...
Wolfgang
