AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
ACADE - How to change or adjust line number tagging threshold
2 REPLIES 2
370 Views, 2 Replies
Is there a way to change/adjust how AutoCAD electrical determines what line number to use for tagging.
Example: If I place a component in the middle of two reference line, ACADE tags the device using the lower line number.
We work from top down, so the componet line number should not change untill it is on the next line (or at least a little closer)
2 REPLIES 2
Flapsie
Have a look in the drawing properties of your file, you may be able to tweak the settings there a bit to get what you are after...
in reply to: Flapsie
Seems like this is hard coded into the software.  I have 0.5in grids with 1in line reference spacing.  If I draw a line/symbol just above the 1/2in mark it will label as desired.  The ladder just wont be aligned to the grid.
”Boost
