I've not seen this one, but try this: Shutdown ACADE and go to your USER folder and look for the scratchpad database for your project. It will be projectname.mdb. Delete this file. Make a backup if it makes you feel better. ACADE stores all data in the drawings so this database is only used to expedite certain operations. If you had a temporary memory issue with your PC this database could become corrupted. By deleting it ACADE will rebuild it from the drawings when you re-open ACADE. If the problem was with data integrity, it will be repaired. Try to automatically assign wire numbers again now.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
