Looking at Electrical 2014 and when I insert a terminal, specifically one that should not change wire numbers, the numbers change on the other side of the terminal.
I have also checked to make sure the drawing template did not have any rogue terminals located in it.
Anyone else see this issue?
Darren
Hello Darren,
It depends on which terminal block you have selected to insert on the wire. If you have selected HT1001 (i.e terminal with wire number change) then it will give a new wire number after the terminal.
Secondly, if you have checked the checkbox in project setting for wire number as "on Per wire basis" then also it will change the wire number.
