AutoCAD Electrical General Discussion
Member
JAXXCAD
Message 1 of 2 (606 Views)
ACADE 2014 RESETTING DEFAULT MENU/ICON MENU
606 Views, 1 Replies
05-07-2013 12:06 PM
During process of setting up IEC menu and Icon menu, lost info for default JIC settings.  How do I reset to default settings?
dougmcalexander
Message 2 of 2 (598 Views)
Re: ACADE 2014 RESETTING DEFAULT MENU/ICON MENU
05-07-2013 02:37 PM in reply to: JAXXCAD
It sounds like you selected IEC as your default standard. That's okay. Just go onto control panel>programs and features and select AcadE 2014. Run the Add/Remove/Change function and select the JIC library as a secondary. I would suggest NFPA over JIC though. NFPA is more up to date.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
