AutoCAD Electrical Forum
ACADE 2014 Publish to PDF Fatal Error
4 REPLIES 4
Matt116
900 Views, 4 Replies
ACADE 2014
Windows 7 Pro 64bit
I've been using the publish to PDF for the last 2 years without any problems then this started all of a sudden.
Steps leading to error:
Activate the desired project
Right click project name and select Publish > Publish to DWF > do all > ok > Publish to > PDF > Publish Options > multi-sheet > then publish.
Some times it prints 2 drawings other times it will print 20 drawings, the file I'm trying to print has 27
then I get this error "FATAL ERROR:  Unhandled Access Violation Reading 0x0000 Exception at d22e296eh"
I get the same error even if I select single-sheet.
I recreated the DWG to PDF PC3 Plotter config file...still get same error.
I removed then reinstsalled ACADE... still get same error.
I can however control-p on a single drawing and Plott to PDF without issue.
any thoughts?
4 REPLIES 4
in reply to: Matt116
Hi Matt,
Sounds like a user permission problem.
Check to make sure that you have read/write access to the plot files.
If you run with UAC (User account control) on try turning it down, giving you more Admin rights.
Any time you see "Unhandled Access Error" it means you do not have adequate permission to access the files.
I hope this helps,
James Alger
Matt116
First thanks for the reply.
I thought about that to but I've published this particular project to a multi-sheet PDF 3 times in the past month and then all of sudden I'm getting the error. I can also modify the project and drawings. My permissions on the folder containing the project and drawings is set to full control. Are there some permission settings in autocad?
hmmm,
No there are no specific permission controls embedded in AutoCAD.
I would check to make sure that you can edit/ use files in:
"C:\Users\<user name>\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Plotters"
It could be locked by the domain (if your machine is logged on to a domain... it would look like you have permissions but you won't be able to add or remove files)
I have posted my dwg to pdf file, maybe yours got corrupted and wasn't fully wiped away with the last repair/reinstall.
I hope this helps,
James Alger
Matt116
Yes I can edit my plotters and my PC is not on a domain.
Thanks for the attached PC3 file but the issue still remains... until I can devot more time to this I can print to DWF then use true view to print to PDF.
Thanks for your help
Matt
”Boost
