AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
ACADE 2012 Multiple balloon insert gone wrong
2 REPLIES 2
AScorgie
753 Views, 2 Replies
When inserting a balloon for a component that has multiple catalog references, the balloons are not inserted adjacent to each other. To get them aligned I must UnGroup the inserted balloons and then drag them into postion.
Is there a way to correct this insertion problem?
2 REPLIES 2
dougmcalexander
in reply to: AScorgie
Be sure you haven't changed the balloon Direction options.  Version 2012 features the option to assign the direction of the additional balloons (i.e. up, down, left, right).  It will remember the last setting used.  Watch the command line prompt as you are inserting balloon leaders (see attached screen capture).  I haven't seen any negative issues wit this new feature, but you have to be aware that it will default to the last setting.  I always use angle with last segment.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
I am also having a problem with this.  Has there been any resolution found?
”Boost
