AutoCAD Electrical General
NetNathan
Message 1 of 3 (228 Views)
Accepted Solution
ACADE 2011 "Locate File" error
228 Views, 2 Replies
02-15-2013 10:24 AM
Everytime ACADE 2011 starts up it keeps giving me a "Locate File" window.
The File:
C:\Acade 2011\AeData\Proj\608661\608661-03.dwg is not fouind at the defined location, or in the project folder for project 608661.  Click OK to locate manually.
The drawing IS in the directory!
I click OK, locate file and have tried the Open, and Locate buttons, but I keep getting the same error on strt up.  I have even tried oipening the drawing and saving, but sane error.
Any ideas?
algerj
Message 2 of 3 (213 Views)
Re: ACADE 2011 "Locate File" error
02-15-2013 01:04 PM in reply to: NetNathan
Hi Nathan,
Remove the drawing from the project.  (right click on the drawing select "Remove")
Then readd it. (right click on the Project and Select Add Drawing)
should solve the problem.
James Alger
SolidCAD
NetNathan
Message 3 of 3 (181 Views)
02-18-2013 02:10 PM in reply to: algerj
That fixed it.  I had tried this before, but the project was not active.  After making project active and doing what you said... everything ok.
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
