During the deployment configuration, did you tell it to share the catalog
information? if so, was this shared to a location over the network? If so,
this could cause it to take a while since what it is doing is actually
taking each individual manufacturer MDB file and merging it into the main
MDB file and there are tens of thousands of records. I have never seen it
take 3 hours thought.
One thing you might look at is if you shared the catalog data, look at the
location you shared it and see if the MDB files, like DEFAULT_CAT.MDB, are
getting bigger, if they are that means it is still working. In Acade 2008,
the size of this file should be around 115 Mb total. There are other MDB
files also, but this is the largest.
Steve
wrote in message news:5905053@discussion.autodesk.com...
Hi Steve,
Thanks for your reply. I did have anti-virus running but in th epast we
disabled on-demand file scan. However disabling this totally and
uninstalling it still has not had any effect...its still sitting there doing
nothing (visibily anyway)
Kind regards
