Hi Barry,
Do you mean that your menu "works" as far as popping in your custom symbols,
it just does not show the image in the menu? If this is true, the problem is
(probably) that your slide ".sld" images need to be in the same folder as
the icon menu ".dat" file.
Nate.
wrote in message news:5015074@discussion.autodesk.com...
I have used ACADE 2004 for 1 year and now we have upgraded to ACADE 2005. I
have created custom symbols and slides and added them to the menu using the
Menu Wizard. We have recently moved to a new office and now when I use the
insert component, the menu doesn't show the components. How can I fix this?
We are using a network version of ACADE. Please help.
Barry Hinschberger,C.Tech.
