AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
A software problem has caused AutoCAD
4 REPLIES 4
3742 Views, 4 Replies
Problem AutoCAD Electrical 2013 when open file and working
A software problem has caused AutoCAD electrical to close unexpectedly
FATAL ERROR
see Attachments
windows XP sp3
4 REPLIES 4
Hi Gruychev,
Do you have a screenshot of the error that you can post?
Your post is a little vague.
James Alger
SolidCAD
rgruychev
in reply to: rgruychev
Its a permissions issue.
One or more of the folders that you need to access are locked down.
Are you a local admin, or are you running a domain admin / user?
Sometimes IT people Lock your Roaming or Local Profile (which ACADE needs full access to).
They set some folder permissions that pervent access for the program.
The other things that sometimes does it is the UAC (User access control) is set to high.
(Windows updates seem to screw up the UAC until you do a hard boot.)
If any of the files reside on the network, try rebooting the server.
I hope this helps,
James Alger
Is it the following step to crash the ACE2013? or you have different workflow?
1. Open ACE2013
2. File Open to invoke the Open dialog, then select the drawing to open
3. Then crash
Would you please help to send the drawings to us for analysis? Have you patched the SP1 for ACE2013? My email is zhonghua.shou@autodesk.com
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
”Boost
