AutoCAD Electrical General
Active Contributor
David_S_Barrow
Message 1 of 4 (258 Views)
3D Move
258 Views, 3 Replies
05-27-2011 05:33 AM
When I'm creating a 3D panel layout in AutoCAD Electrical 2011, if I decide to move an object using the AutoCAD Move command, whilst the object is on my cursor. I change my point of view using the orbit command all the other Objects in the drawing disappear? Which makes it impossible to use any other geometry to position my object.
Valued Mentor
hardin
Message 2 of 4 (248 Views)
Re: 3D Move
05-27-2011 01:20 PM in reply to: David_S_Barrow
If you have an object selected, it will isolate once you begin to orbit. That is a natural feature.
If you are issuing the Move command, THEN try orbit, it should continue to show everything.
Try turning Hardware Acceleration off to see if that helps.
Is the item you're moving close to the items you are moving to? If not, then maybe orbiting is just swinging the object off the screen.
Learn, Practice, Get Better
http://autocad-lkh.blogspot.com
Active Contributor
David_S_Barrow
Message 3 of 4 (226 Views)
Re: 3D Move
05-31-2011 08:42 AM in reply to: hardin
I select an object to move it. I then use Shift + Middle Mouse button to rotate the display, the whole model stays visible whilst I'm rotating it but soon as I release the mouse button and shift key the rest model vanishes, leaving the part I'm moving which stays visible on the cursor. Turning off the hardware acceleration doesn't cure the problem just makes the model rotate very slowly.
Distinguished Contributor
s.wile
Message 4 of 4 (208 Views)
Re: 3D Move
06-02-2011 06:40 AM in reply to: David_S_Barrow
Since this is more an AutoCAD question you may have better luck posting it over on the that group.
Stan Wile
Stan Wile
http://myacade.blogspot.com/
IMAGINiT Technologies
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
