Please see the attached drawing.
For some reason, the first wire number is "5-1B". It really should just be "5-1". Why is it "B", how do I fix this? Also, on rung 5-2, there are some "short" wires to the left of 5-2 that should be numbered, but no matter what, they will not number. Any ideas here Thanks!
Also, after I learn this, I want to delete the entir 5-2 row anyway. What is the best way to go about this without "blowwing up" the ladder and PLC, in other words having to redo them both from scratch? Thanks again.
Solved by rhesusminus. Go to Solution.
Hi.
Thanks rhe. So the first question is how do I set up that termianl to trigger a wire change?
Also, say I do not want the oV rail to the right to be 5.1. How to I change that? Thanks again.
To delete the rung WITHOUT having to "blow up" the ladder is easy.
1. Under the Wire Number section, there will be a tool to erase wire numbers. Use this to erase the wire numbers from the section you wish to delete.
2. Under the Insert Component section, there will be a tool to delete inserted component. Use this to delete the components you wish to.
3. Under the Insert Wire Section, there will be a tool to Trim/Delete wires. This is the last tool that you will need. Use it to remove the wire you wish to remove.
Regards Brad
Brad Coleman, Electrical Draftsman
